21 - 40 of 224 Posts
$25 harbor freight tool cart some scrap metal. im going to make an aluminum water tank for the cooler to go above the welder. I might mount my plasma or MIG on top. still need paint.
mine isnt quite as clean as some of the others but heres mine i just finished up. I put the metal plate on the top because it will double as a work table and welding table since I don't have room for a decent sized table.
the base is from a old pressure washer cart
Still have to finish it but it will have diamond plate aluminum sides. the top will be clear lexan and the front will be a flip out cast iron trash chute door..
Maybe i will play with it next week....Its made from scrap.
Addicted to Gear Oil
I used the larger HF utility cart, cut a round hole for the tank to drop into (supported by the bottom level) no need for a chain to hold it up. Tools/clamps/grinders up top, HH210 on the bottom, and a set of hooks to wrap the 50' extension cord. I'll have to see if I can find a good pic to post...
Looks like you have a slight camber issue :laughing:
I'm going to have an 80cf bottle behind the welder and a powermax 45 sitting above the welder on this cart if all goes well soon.
My Welder/Plasma kart
I've wanted to increase so floor space and reduce some cords getting tangled up on the floor. So I stacked my small lincoln and my plasma on. I figured since the plasma needs shop air i would put an air reel on the kart.
http://
Everyone has to do dimple die holes right?
Both machines are grounded together and one cable to the bench or whatever.
Since the plasma needs air I put an air reel on the kart also
I ran the 220 power cable, air line, and an extension cord through a nylon sleeve. Everywhere there is 220 in the shop is also 110 and shop
air.
I built this one a few years ago. The Thunderbolt stick welder has been replaced by a Powermax 1000 plasma :smokin:
Hoff,
You need to quit posting..........how did you manage to pimp out a welding cart? :grinpimp:
Like always, your attention to detail is amazing!
Hoff, That is THE POOP. I would buy that. Did you start from scratch or build off something? Awesome details and very well thought out.
