Did a search and found zip....
Can a cast iron exhuast manifold be welded ? Looking to weld a hard to find/replace early diesel engine manifold. Crack was due to a motor mount failure and bump stop missing.
The crack is around the collector outlet and is cracked 75% of the way around the pipe. It can be taken off and cleaned and prepped prior to welding.
Can it be welded satisfactorily ?
bennett
bennett
