Hi,
I am installing a ram-assist steering system on an Early Bronco.
I will be welding brackets for the ram-assist to the track bar riser bracket. The brackets are cut from 1/4" plate.
I originally thought that welding the brackets (really just large tabs) on both sides of each bracket would be required. Because of tighter spacing between the brackets, it might not be possible to weld the joints from between the brackets. After a little searching, I found references to only welding tabs/brackets on one side to prevent weakening the metal/joint.
Any thoughts would be appreciated.
Thanks,
Jeff
Thanks,
Jeff
