1 - 10 of 10 Posts
What is the attraction of moving the front diff forward and is it possible to flip the springs and leave the shackles where they are?
Approach angle!!!!!! Longer wheel base... A couple of reasons. It is possible to flip the springs and not do a SR. But you SHOULD either have a second military wrap spring made or punch another hole in the springpack. The military wrap should always go on the frame end not the shackle end...
Originally posted by JasonH:
<STRONG>How does this affect your steering? What has to be changed?</STRONG>
When I did my saginaw conversion I did the spring flip as well. Everything fit just fine and I was spring under. I am SO now and everything fits just fine as well... Also you might want to think about getting longer brakelines <IMG SRC="smilies/eek.gif" border="0">
And moving your bumpstops to a place where thay are usefull again. The sound of tire rubbin on front fenders is a bit annoying....
<IMG SRC="smilies/wink.gif" border="0">
I also did a saginaw conversion and hysteer arms from all pro at the same time. everything went in just fine though <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0">
Great, look like the go eh! I am fitting P/steering from a 60 and it looks like the arms will line up perfectly if the diff is moved forward.
Thanks <IMG SRC="smilies/biggrin.gif" border="0">
did this, and yes well i did 60 first in front of the shock tower and then moved diff, its too easy! (well it took mea long time, but i have done one since and it cost me about a third as much and easy took half as long! <IMG SRC="smilies/frown.gif" border="0">
pity mine didnt take half as long and cost so cheap <IMG SRC="smilies/crybaby2.gif" border="0">
Discussion Starter · #9 ·
Originally posted by LandCruisersKickAss:
<STRONG>did this, and yes well i did 60 first in front of the shock tower and then moved diff, its too easy! (well it took mea long time, but i have done one since and it cost me about a third as much and easy took half as long! <IMG SRC="smilies/frown.gif" border="0">
pity mine didnt take half as long and cost so cheap <IMG SRC="smilies/crybaby2.gif" border="0"></STRONG>
What did you do with the shaft near the firewall, and do you have more pic's other than whats on your website?
1 - 10 of 10 Posts
