1 - 10 of 10 Posts
Good luck!
Dynatrac does not like giving out P/N's or info because they want you to buy all your parts from them. I have several friends with dynatrac axles and when they tried to get a spare parts list, dynatrac said "NO".
They make nice stuff, just a pain to deal with
Brian
do you own one?
post pics, id'ing them should be no big deal with some visuals
their new website is nice
15" wheel guys should like the 1/2 ton brake swap on the 60
[ 11-03-2001: Message edited by: mj ]
Originally posted by mj:
<STRONG>do you own one?...</STRONG>
No, I don't...I can't personally justify spending that kind of money when I'm not competing or making money off my truck.
A friend just bought f&r axles and we have them all done under his Jeep but can't figure out what brake-lines to use to connect to the calipers.
Moderating Midget
That is bullshit! When I bought my axles from Sunray, they provided me with DETAILED parts lists of every component and where they came from in case I needed a part while on the road wheeling.
That is just plain ole' good customer service. What the hell is the secret?
My front brake lines are flexible extended rubber ones from a YJ.
take the calipers to a hydraulic shop and have them give you steel adapters to run real hydraulic lines?
like i said previous, post a pic of the brakes in question and guys on here will go, 'aw shite those are just -----'
mj said:
take the calipers to a hydraulic shop and have them give you steel adapters to run real hydraulic lines?...
Be careful when you do that. The hyd shops down here won't build lines for brakes due to the risk of the line failing and resulting lawsuit.
1 - 10 of 10 Posts
