1 - 13 of 13 Posts
hey guys, what cams are you running in your 350? how does it sound? specs on the cam? how much power are you putting out? what other mods do you have done? thanks!
greg
· nice roach.
Heres a pic of my cam card.... its in a 383.... Im using 1.6 rockers so the gross lift ends up being @ .512. Heres a link to another thread on here with the specs to my junk......click here
competition cams energizer 270 h works great with a stock 350 4bbl lots of low end and the 4 barrells sing real crisp too barely lumpy
jhama78, who cut that cam? Have you run that motor yet? No prob with the valve clearence? I like the specs of that cam, I ruined my old cam, had pretty close to the same specs and want to rebuild it. I hope to have my 383 in my Blazer by the end of the year.
· nice roach.
The cam came from
PBM performance products
7301 Global drive
Louisville Ky 40258
I havent run it yet but hope to within the next two weeks. My biggest obstacle is that I am 50 miles away from my truck during the week so I cant work to get it ready except for the weekends. Ill letcha know how it does once I get everything together and running.
l8r
-j-rOd
· nice roach.
spoolnaround said:
have you checked the valve clearance with the 1.6's yet?
I spoke with the guy that helped me build the engine and he is completely confident with this combination.... I guess we'll see what happens if things arent matched correctly....:nuke: :D
Mines a reground ZZ4 roller cam in a late vortec engine. Here is the Desktop dyno file I used when planning it.
.465 lift with 270* duration is pretty close to where we ended up. I can't find the cam card right now, but it's not too far off.
· Premium Member
I'm running almost the same cam. But a little more duration. Flat top pistons with small reliefs, about .005 out of the hole. With no problems.
Go for it! Great cam for a 383.
· nice roach.
Good to hear man :D I will most definitely let yall know what happens when I fire it off for the first time.
· Premium Member
It was pretty acurate on my current motor. Witch I have had dynoed. And the Hp / Tq curve was very close. The only unknown was the actual flow numbers of my heads.
On the motor I'm building now I have had the heads on a flow bench, so I can punch in the actual flow numbers. It should be real close.
The best thing is you can see how different cams will effect your set up. Cool shit!
My engine is a .030 over 400 SBC not a 350 but here is the specs on the cam that I have in it. It is a Crane Energizer 282H06. It has .470 lift, 282 Adv.duration, 226 duration at .050, & 106 lobe seperation, with 1.5 rockers. I have an old version of desktop dyno and it puts my engine at 347 HP, and 465 TQ. It has a good choppy idle and sounds good, but might be a little large for a 350.
1 - 13 of 13 Posts
