1 - 18 of 18 Posts
I've got to figure out what do for an X-member for my ZF-1356-NP205. I came up with a combination C-channel/ Dual tube setup and started on it last night, but getting around the driveshaft yet keeping as much of the member from being above or below the frame rail is tough.
Lets see some pics!
Wow, my tranny is much lower.
my tranny mount bottom mounting surface is flush with bottome of frame.
Any issues with body clearance there?
(Is there any tech on p4x4 anymore except in the IH section?)
What I am currently looking at doing is similar to what you have, except using two tubes, one on each side of that plate, then bending them up at 45 degree angles until they meet some 3" C channel. Then the C channel goes to the frame and mounts with a similar "drop out" style mount.
Cause tranny crossmembers qualify as super hardcore tech. :shaking:
I measured, I thought, I designed, and if I had a plasma I would have cut them out, too. I ended up having the flat stock laser cut.
I have a friend with a bender and I thought I might have to do a \_/ shape in the middle of it. Turns out I didn't need to. The tube is even with the bottom of the frame.
This is a 80, not an SII. IIRC you are putting ford stuff in? Any pics with the trans in?
I moved pics around in my photobucket, sorry for broken links.
Is that a 241/205? Been thinking about it myself. Are you going to go over the tcase? Maybe weld some tabs on the steel plate between the adapter plate?
Discussion Starter · #11 ·
It's a 1356-205.
I'm going underneath and using a stock 4x4 ZF tranny mount. I am not planning on running a torque mount off the 205 since the 1356 never had one. Therefore I can't mount off that plate although it is very tempting. I still don't know about the torque mount.
Discussion Starter · #12 ·
No, you've reached the end of the internet and you're the last intelligent life left.
Get a bender, bend some tube, install your junk.:mr-t:
This is a prime example of the kind of answer you get from a non-IH'er and the reason for my statement.
Discussion Starter · #18 ·
Here's what I came up with, but I'm gonna redo it a bit.
I think the plan will be to redo the X-member by boxing in the bottom with .125" thick strap and then I think the ends will be changed so that they mount with a single horizontal bolt going through two 1/2" tabs and then a piece of pipe welded to the x-member.
Not sure how torsionally rigid U-channel is, even though it is pretty thick, so I don't think boxing it in will hurt.
1 - 18 of 18 Posts
