1 - 20 of 31 Posts
I measured and it looks like if I get rid of the factory crossmember and do a cusom one with the tube bender that is coming, I will be able to mount the double throw ram above the pinion in the front and way up out of the way. With the bump stops compressed a full inch I am still left with half an inch of clearance. This works because I moved the rear axle back 9 inches which places the ram right in the middle of the highest point on the frame in the back. Just got to get rid of that pesky crossmember. Does anyone see any reason not to do this??
elf_cruiser said:
you paid money for histeer arms??:rolleyes:
What's next? Ya gonna hire a guy to wipe your ass for you??
:laughing: :laughing:
After I read that about his arms, I was like damn, i better not ever go wheeling with him. My $10 steering arm I am going build is going look like shit next to his.
damn, ten bucks!! You got ripped off too, mine was $4...
Ohh, after a year and a half, it still works great. It's a fawkin chunk of metal with 4 holes in it, WTF is there to spend $ on???
yeah and the fact that elfcuriser toasted a chopsaw and his arm in a turn like the rest of his rig:flipoff2:
Sorry Lee, But when you get to AZ, we'll look at your Rockwells the same way we look at 30s:flipoff2: (Ok well not quite the same, but either way your not getting through some of the trails:p ) Just ask Wes.
This is Jeeper111 on my sisters computer but I think your problem is your not willing to lay it on its side and drag it though like I am. If it is too narrow I will go up and over with the winch or not. Sure there will be some easy obstacles for you that this aproach will make crazy for me but I welcome the challenge and at the same time, there will be obstacles that I will do easily that will be hard for you and I bet there will be more of those. anyway, ask wes how much easier those tight spots would be with rear steer which I will have.
Did you not look at the pic I just posted in the AZ wheeling thread:confused: :D Seriously man, your Jeep is fawkin awesome, but there are some(not all) trails out here that you REALLY wouldnt want to go on, rear steer or not. Im not talking about manueverability, Im talkin you physically wont fit in the trail.You are wider than Wes right???
Yeah I looked at it but if you look at those pics, there isn't anything there I wouldn't be able to do. In some instances it might mean that I will have farther to fall if it slips sidewaysWhich it is less likely to do because of how wide it is and less likely to do damage because of how far out the tires stick. I would be higher up in those tight V shaped spots but it just means different lines and approaches. We will see when I get out there. Are you going to come wheelin with us in may???
Moderating Midget
You guys just get lots of pictures.
:laughing: :laughing: :laughing:
Back to topic...
I would be carefull with only 1/2" of clearance. I thought I had about an inch of clreance between my ram and oil pan, then I dropped off a 6' ledge and put my ram into the oil pan. If you think you need 1/2", at least plan for 1".
1 - 20 of 31 Posts
