1 - 11 of 11 Posts
· Premium Member
HEY LOOKING AT BUYING A 01 DODGE HD 2500. 5.9 GAS ENGINE AUTO. WHAT AXLES DOES IT HAVE LOOKS LIKE A 60 REAR NOT SURE ON THE FRONT AND WHAT TRANNY TRANSFER CASE WOULD IT HAVE ? ANY IDEAS ON AXLE GEARING WITH THE AUTO ? ALSO WHATS THE LARGEST TIRE I COULD SQUEEZE ON WITHOUT ANY LIFT ? 33'S/35'S ? ANY INFO WOULD BE APPRECIATED. :flipoff2:
V8 2500s have Dana 60 front and rear, You have either a 241 or 241 HD T case .HD cases have pto provision. You can fit 33's stock and get 35's with a leveling kit. Gears are going to be 3:55 or 4:10's
It wil lhave the 46RE for the Auto trans.
· Premium Member
HEY THANKS. IS THERE A SETUP FOR CONVERTING TO MANUAL HUBS ON THE FRONT ? ANY IDEA ON AXLE SPLINES IN THE FRONT AND REAR ?
I have yet to see a v8 2500 with a 70.
The dynatrac conversion wont work on the 00 ups. The ball joints are different amoung other things.
Ive been told right has a manual hub conversion for the 00 ups for 1800. I think thats very expensive. Give them a call to see if is available. You will be stuck with 30 spline 1.31 shafts. For that kind of money you can sell you current axle and do a HP swap
Ive also seen the 2500's with camper and tow packages with the 60. If they are out there, its the first I seen. A few people told me they have had 70's in the rear and I would eat crow if they could prove it to me. They have yet to offer a pic of the RPO codes.
· Premium Member
Discussion Starter · #9 ·
THIS TRUCK HAS EVERY OPTION EXCEPT LEATHER AND A LARGER MOTOR ACCORDING TO THE DEALERSHIP I WORK AT. I WILL GET THE VIN AND CALL TO FIND OUT EXACTLY WHAT IT HAS. IT HAS THE CAMPER TOW PACKAGE. I LOOKED AT THE REAR QUICK AND IT LOOKS BIGGER THAN MY 60 REAR IN MY JEEP SO I WILL CHECK WHEN I BUY. THANKS FROM A SOON TO BE DODGE GUY :flipoff2:
Just check the RPO codes. They are under the hood but more likely in the glove box on a 2001. It will tell you your axles front and rear, if the rear has a l/s and your gear ratio
· Premium Member
Discussion Starter · #11 ·
HEY THANKS AS SOON AS I CAN I WILL CHECK IT AND LET YA KNOW :p
1 - 11 of 11 Posts
