1 - 14 of 14 Posts
I have an 84 2wd toyota pickup. The truck came from the factory with EFI. Im wondering if anyone knows if the head is the same as 82 22r? I just want to replace my longblock and put all my intake and exhaust on the new motor. Will it bolt up? Thanks
Will work out fine
1983-’84
In 1983 several changes were made.
Some models had fuel injection, but the only difference was the addition of some extra bolt holes to the intake manifold side for the EFI intake. This head will retro-fit back to the 1981-’82 head, but you can’t use the earlier head on an EFI ’83-’84 model.
For all the info you needhttp://www.babcox.com/editorial/ar/ar119838.htm
and on my site you get an idea of how much you can mix and match with 20R 22R 22RE or like I did, 20REhttp://web.ncf.ca/ez273/20R%204Runner%20index%20page.htm
Are you sure your truck is an 84? I was under the impression that none of the EFI trucks wer introduced until 85. Many of these trucks were produced in 84, but were released as an 85 model year.
Stock '84 EFI
There is a stock '84 EFI pickup at a wrecker near my place. It was the first year they offered it as far as I know. Here in Canada at least.
If anyone near the Quebec/Ontario border wants it, I think it's still there. They say it ran fine when they parked it there. They asked 400$ Can. Too much, but I guess it can be negociated.
There is an '86 4x4 with a running motor near here too. It's got 248000 km on it but it's just 150$ Can.
2RowTC4Runner said:
1983-’84
ok so based on the info i quoted ... the 83 and 84 engines are interchangable? i got a line on an 83 without intake or exhaust, so my 84 intake and exhaust should match up to the 83 correct?
from my experience, yes
For my 20R-E project, I had bought an '83 carbed Celica head. It had all the alternate bolt holes for the EFI intake. The only reason I returned it is that it had a worn out cam race.
I'm running my EFI system on an '84 head now. It is the exact same head as the '83 I returned.
To bolt on an EFI intake you nead a head that has 15 holes (not counting the 3 for the EGR) for studs or bolts. You only end up using 10.
your 84 is carbed I presume
If it is, your even more assured that everything will bolt on. Your 84 intake can even be retrofitted to an 81-82 motor. The advantage with those is that you eliminate the timing chain guide breakage issue. Have I mentioned I love those double row TC motors?
Efi was first available on 83 Celicas, next 84 2wds, and finally 85 4wds.
All 81-82 22R's had a single intake bolt pattern. Beginng in 83, all 22R heads had the dual carb and efi intake pattern.
I have seen a number of 82 heads that had the added webbing for the efi pattern, but were never drilled and tapped.
Before you start this conversion, look on the side of the 82 head and check for the proper efi bolt pqattern.
Marlin
that reply was for mobil1syn
But the 84 intake would also fit on the 82 head, as long as the 84 is carb.
1 - 14 of 14 Posts
