1 - 20 of 34 Posts
Found a 78 Dodge 1 ton dually locally for $250 & I'm wondering what the front axle would be? Is it a D60? I always hear about Ford & Chevy D60 fronts, but don't remember Dodge?
Thanks!
Mike
Good to know. Either way, I'll check it out good first, hopefully tonight.
Thanks!
What's a D61?
a bastard D60. you can run D60 gears with a ring gear spacer, but im not to fond of that idea, as are most people around here.
someone else may be able to explain the D61 better than me...
no 61s back then.
I woudln't even look. for $250 I would buy it then worry about if it has a 60 or not.
Hell, if you don't buy it, I will come buy it and then smack you with a dead fish.
Discussion Starter · #10 ·
no 61s back then.
:D
I'm sure I will!! As long as it's not totally trashed. It's got everything but the engine, he says.
Very early trucks came with dually dana 44, (like late 60's), so in that year it would be a 60 front with external flanges. The 61 front only came in diesel trucks during the early 90's that were equiped with the 727 trans. They were designed to run very high gear ratios to gain some mileage out of a non overdrive trans.
This must be ask the same question about Dodge axles week!
I'll give you that, old closed knuckle stuff. I had a 44 front in my 71 W200 that had the large knuckle outers. The "ball" on the ends of the axle were easily the size of a softball.
Travis..
Discussion Starter · #16 ·
Took a look at it tonight & it's definitely a D60. He said he thought it had 4.88 gears, but wasn't positive, maybe 4.10. Anyhow, it didn't look too bad at all. Now I just have to talk the wife into it! She got me into Jeeps, so it shouldn't be too hard, although money's a little tight this month.
1 - 20 of 34 Posts
