1 - 20 of 28 Posts
I am trying to find out what the specs are of a dana 35 and a chrysler 8.25.
I have heard a lot of different opionins on this and I am trying to find out what kind of strenght difference there is on these.
I really want to put dana 44's under it, but at this time the money is not available, so I am working with what I have.
I here some same that a 35 with a super 35 kit is very strong, and then I here that a 8.25 is even stronger, but I can not find any specs to see which is better.
I have even heard that an ford 8.8 is even strong than both of these.
Please explain
Any help would much be appreciated.
go with the 8.8... way stronger than the 8.25 and the 35. Plus you can usually get 4.10's if you find one from an exploder with a sport package. If you get one from 95 and up, they came with disc brakes stock. <IMG SRC="smilies/bender.gif" border="0">
I will supply you with the stock POR answer to this question, even though I am not a subscriber to the club yet....
dana 60 is your only choice.
it's illegal to supply information about the dana 35 on this board
Originally posted by BRUISER:
<STRONG>I am trying to find out what the specs are of a dana 35 and a chrysler 8.25.
Please explain
Any help would much be appreciated.</STRONG>
<IMG SRC="smilies/thefinger.gif" border="0"> 60's 60's 60's is the appropriate answer.....
Dana 35c- 27 spine <IMG SRC="smilies/puke.gif" border="0">
Chrysler 8.25- 29 spline <IMG SRC="smilies/puke.gif" border="0">
Dana 44- 30 spline <IMG SRC="smilies/frown.gif" border="0">
Ford 8.8- 31 spline, disc brakes <IMG SRC="smilies/bounce.gif" border="0">
Dana 60- 35 spline <IMG SRC="smilies/eek.gif" border="0">
Nathan
Originally posted by Jim M:
<STRONG>All I know about the D35 is that it weighs so little that it can be easily removed alone. I removed mine unassisted and loaded it onto my trailer. You would do well to do the same.</STRONG>
the d35 should be light enough for the trashman to pick up on his own
I'm sorry.....I thought you asked a question about......
wait a minute.....are 35's and 8.25's really axles? I thought that was a twig I picked up on the last trail and threw it out! damn...well I gues that getting rid of those flimsy pieces of tin was my first mod....
hell, I went nine inch and 44 off an eb before I even put any lift on!
Discussion Starter · #13 ·
Well let me just say I appreciate the straight answers from a few of you, about the spline and size of different axles, and of course that I should really run 44's, 9' or 60's.
But for the rest that talk big and really do not have a clue about the axles size
You know who you are.
Discussion Starter · #14 ·
Ok another question to add to this.
As it looks right now the best bet for me would to put an 8.8 or a 44 in it.
So If I go with a 44 in the rear then I will also go with a 44 in the front
But if I put a 8.8 in, then what size axle should I put in the front to run 35's?
Super Moderator
'82 Scrambler, '14 Rzr
For 35's - I would suggest a front 44 and a rear 44 or 9".
Anything less will be just not up to the long term use of 35's, lockers, and wheeling.
Discussion Starter · #17 ·
Thanks for the honesty DRM, on what it takes to run 35's safely with the least amount of breakage long term.
What I am currently driving is an XJ, I know it is not hard core, but for the time being that is what I have to work with, until I build another "Hard Core Vehicle"
Bruiser,
Go into a little more detail. You might have said if you currently have a D35 or 8.25, but I didn't see it. Also tell us what year your XJ is. At least it would help me. <IMG SRC="smilies/smile.gif" border="0">
Discussion Starter · #20 ·
TornadoTJ,
I have a '98XJ with an 8.25 in it right now w/ 29 spline.
What I have been doing is pricing what it cost to lock and regear what I have, or what it would cost to upgrade,lock and regear.
I also was just wondering what strenght the 35 is because I have some freinds that run that and I was curious to see the comparison and what he advantage would have been for chrysler to change from the 35 to the 8.25 in the XJ
1 - 20 of 28 Posts
