1 - 11 of 11 Posts
took apart my front end to install arb and look what i found laying in my diff oil...what is it? where did it come from? and do i need it?
It sits at the end of the housing (about 2" in ward of your inner axle seal), and helps keep oil from flowing into the knuckles.
so this would be a pain in the a$$ to get back in...is improtant? should i try to put it back in? or can i get by without it?
I don't know how hard it is to put one back in. I've never had to do it.
Mine came out, too, a long time ago. I never bothered to put it back. Should be OK without it (I hope). No problems yet, anyway.:D
Although it does make it a little more difficult to slide the axle in. Mine came out of the long side. It acts as a fulcrum to keep pressure off the oil seal when you push the axle into the third member.
Discussion Starter · #9 ·
i looked down my axle tube and didnt see another one so dont know where it went, so ill go without it... probally be a pain in the arse to put back in anyway...thanks anyways guys- onward
The other one prob. got ground up. It happend to me about a year ago, I think I knocked it out of the housing when I installed my longfields. I was in JV at the time, so I went wheeling right after they were installed. When I got home and serviced the truck, I found LITTLE slivers of that part stuck to my drain plug!
1 - 11 of 11 Posts
