1 - 3 of 3 Posts
I am wanting to put a suspension lift on my 92 4runner. I was wondering on what would be the best and most affordable one without doing a sas on it and still having plenty of flex and more ground clearance. The truck is used mainly for moderate trail rides and I would like to run around 33's with no problem any help would be useful. Thanks.
im a firm believer in not spending moey on lifting ifs because you probably will not be happy with it at some point and have a bunch of money tied up in a front end you wont want anymore. A cheap way to clear 33's is to run a lift shackle in the rear, crank the torsion bars in the front, add a 2" body lift and remove the inner fenders. Works as well as anything else and will only cost you $150 in parts that you can still use should you decide to swap in a real axle at a later date. Thats how I did mine, and I was very happy that I didnt waste any unnecessary money. With that and a rear locker you'll be able to go most places you want to go.
Josh
1 - 3 of 3 Posts
