1 - 11 of 11 Posts
I am swapping a D44HP from an F250 and will be running some blingy ass H2 wheels. What lug nuts should I use. The standard 1/2-20 nuts that were used on the steel wheels are too small and the H2's use some metric 14 mm. Anyone have a brand/part number for a reasonably priced piece?
What part of "The standard 1/2-20 nuts that were used on the steel wheels are too small" did you miss? LOL :flipoff2:
welndmn said:
to small as in how
Too small as in the OD of the conical section of the standard lug nut almost falls through the hole in the wheels. I am going to NAPA tomorrow and will see what they have. I talked to them on the phone and I have prices ranging between $1.25 ea to $4.00 each! :eek: I don't want to be spending another $100 plus on just some fawkin lug nuts!
go the JY and get some bigger lug nuts..
My 88' F-250 uses 1 1/8" lug nuts...
I think you'll find they are actually 9/16" threads.
JJS...you are right. I went to NAPA and they have some bulged acorn style which have a larger flange. I am still looking for a cheaper alternantive although I don't mind spending a buck or so a lug, just not $4 each! I'll have to see how much the McGard brand are. I used these on my van when I bought the AR wheels and they have no signs of rust or even scratches!
Thanks for the replies so far.
yeah, I meant they fit a 1 1/8" socket, indicating they are a rather large overall sized nut, that should not have any problems slipping through the holes on a H2 rim..
I buy my lug nuts from www.patchboy.com. Great prices on just about any size or type of lug nut you might want. I like the open-end, bulge lug nuts with a 13/16" hex size. Those should have enough surface area in the cone. I'm assuming that you've already confirmed that your wheel studs are the normal 1/2-20 thread since your old nuts will thread on. I'm not familiar with the Hummer wheels but you might want to confirm that they use the conical seat style lug nut.
1 - 11 of 11 Posts
