1 - 8 of 8 Posts
What kind of master cylinder with a yj booster and rockwells.Tryed the search with no luck.With the stock master cylinder I get so much front chatter(detroit I guess) it's scarey.
If you are using pinion brakes, I did the mazda rotor, toyota caliper and the stock TJ master cylinder and it works kick ass.
Discussion Starter #5
It's pinion brakes.That's the same caliper and rotor.Are you using a porportion valve.I have so much chater for the front end.Wonder if my detroit is going bad?
cheap2.5 said:
It's pinion brakes.That's the same caliper and rotor.Are you using a porportion valve.QUOTE]
Yes, I used them front and rear to turn down the pressure and try to equalize the brake power front to rear.
I have always been under the impression that only one proportioning valve was needed, and on the rear. Why did you use one on the front?
Travis
1 - 8 of 8 Posts
