Ok I just spent the last 1.5 hrs at the DMV and then talking to a Kansas Hwy Patrol Officer to get all of my info. I now have have some questions for you all. The Kansas law is that the tag on the trailer has to be high enough rated to cover the weight on the trailer axles, the tag on the truck has to be high enough rated to cover the total GCW. For me to do this I would need a 26K tag on my truck and pay and extra $270.00 per year just for the tag.
The set up is a 03 Ram Cummins 3500 dually 12k GVWR with two Jeeps on a 34' low boy goose neck with tandem 8k axles and 16k GVWR. The trailer has a 16k tag and the truck has a 12k tag. The weight works out to between 10.5k and 11.5k on the truck axles and between 13.5k and 14.5k on the trailer axles. If the trailer is towards the heavy end the truck will be towards the ligher end and vice versa.
Now for the question, if I am rolling down I-70 headed to Moab in either KS, CO, or UT, get pulled over and the officer weighs the rig, looks at the tags, and gives me a ticket will they make me unhook the trailer and leave it for a "under tag violation"?
In KS the "under tag violation" is a $40.00 fine with a $60.00 court cost.
I also do alot of work in an area where the streets are Blvds and have no truck signs, if I were to get a 26k tag I could then be given a ticket for driving on a Blvd even when empty and not towing any thing.
I will pay the ticket I just don't want to have to leave the load.
Thanks for your input.
Scott
Scott
