1 - 13 of 13 Posts
Moderator
Hi,
quick questin about transfer case on 2003 TJ's. My buddy got one taht has the 16valve engine. Does anyone know if the transfer case that comes with that is still NP231 or has it changed?
Thanks,
Gui
Imkunfused said:
If the SYE is for a YJ, it wont work.. different style outputs.. Now if its for a different version of the 231 in the tj's it will be fine
The last HD SYE I did for a TJ was identicle to the YJ ones. You replace the output shaft and rear part of the case anyways, so why won't it work??????
Depends on what you use.. if you have the full sye kit then yes it will work, if its the hack and tap kit, it wont
1 - 13 of 13 Posts
