1 - 8 of 8 Posts
When I installed my lockright in the rear of my 86, the manual for the locker said to use 85w140, which is what i used. I dont know if it is from the real thick gear oil, or a combination of the oil, new 31 muds, and locker; but my gas mileage has gone from 330 a tank, to 230-250. I realize there is a slight difference in the speedo now, but only a few %. Will changing the gear oil to 80w90 effect the mileage at the cost of increased noise, or should I just leave it. I live in AZ, so the temps are higher than other places if that changes anything.
I have ran 80/90 in my 44 for 2yrs now and my locker is a little noisy but I have had it apart a few times and it isnt worn at all anywhere. I live in Washington so the temps are mild but I would imagine you should be fine. As far as mileage I have never heard of oil viscosity effecting gas mileage Are you heavier onthe pedal because of larger tires? The stock 4.10s should be low enough for 31s.
lots of factors can decrease your mileage.
if you didn't change gear ratio's, your truck is working harder to turn a larger tire, and the added lift increases drag, ect.
i'm using Morie's stablizer in all the boxes in the truck, and it's like jelly compaired to 80/90w. it's made a big difference in temp. i've got 70/30% Morie's/gear oil mix in the diff's, 50/50 in the tranny and t'cases. the shifting improved dramaticaly!
mileage has not changed.
hope to see ya on the crown king trip!
330 miles out per tank. You must of been driving down hill with a tail wind <IMG SRC="smilies/biggrin.gif" border="0"> I'm always around 220 if it's just city driving.
The only noise you'll get is in corners and then you'll only hear it in parking lots. It's part of having a capable wheeler, I'm suprised you got muds, they make noise too.
Originally posted by Clifton:
<STRONG>330 miles out per tank. You must of been driving down hill with a tail wind <IMG SRC="smilies/biggrin.gif" border="0"> I'm always around 220 if it's just city driving.
The only noise you'll get is in corners and then you'll only hear it in parking lots. It's part of having a capable wheeler, I'm suprised you got muds, they make noise too.</STRONG>
i'm lucky to get 18 in the city! what wrong with your truck. it must not like gas!
<IMG SRC="smilies/crybaby2.gif" border="0">
Originally posted by Arnold:
<STRONG>He must have a big a$$ gas tank. <IMG SRC="smilies/biggrin.gif" border="0"></STRONG>
I am serious on this one... My old 85 got 250 or so with 32s and 4.88s. I have to run it til the fuel light is bright, but it does, well did. Thanks
my lockright is working great after several thousand commuting miles and mild trails. i use a combination of 80/90 and water that seeps in from the deep water crossings above the diff breather and computer.. <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/thefinger.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0">
1 - 8 of 8 Posts
