1 - 20 of 62 Posts
In the market for some new axles but keep going back and forth between a 14 bolt and a 9 inch aftermarket axles.
Anyone been down this decision path lately? Recommendations? Thoughts?
Whats a better value?
Aftermarket 14 Bolt
-Heavier stronger housing 4", .5" Tubes?
- Gears are stronger than 9" front and rear?
-40 Spline ARB is under $1K
-Gears are cheap
-Are people breaking 14 bolt gears regularly with reasonable amounts of power < 500hp?
Aftermarket 9 Inch
-Housing is cheaper to start
-Lighter, Weaker housing 3.5", .25" / .375"?
-Needs to be trussed?
- 40 Spline requires Comp ARB $2300?
- Third Member Housing another $1K?
-10" gears are stronger front and rear? more expensive
- Spidertraxx Pro Series knuckles will those handle RCV Big Bell Shafts?
I'm not understanding like half the points you made about the housings, pretty sure you can get a 9" housing in any size tube you can get a 14b.
14b is probably more bang for your buck, but the availability of high pinion for the front 9" is nice.
9" ARB is notoriously weak unless you get the $$ version.
Drop out 3rds are the shit.
14b gears are normal priced, where hi9 and big boy gears for the 9/10" are $$
drop out third.
Discussion Starter · #9 ·
Off the shelf I have not seen any fabricated 9 Inch housing 4inch tubing or 1/2 inch thick. Spidertrax has 4" version but it's all chromolly and $$$$
Rolling Mod
Tube works also has a 4”. $$$
1 - 20 of 62 Posts
