1 - 2 of 2 Posts
Whats a rear d60 from a full size worth?
How hard is it to put full size axels under my eb D44hp upfront and d60 rear
rear dana 60 depends on condition/spline count etc $50 to $200 in my opinion.
the hardest thing about that swap is moving the C bushing mounts on the axle. Many of the high pinion frontends had the c bushing mounts cast into the outer section of tube. These can not be moved practically. the welded on C bushing mounts are a project to grind off. Supposedly Duff sells new ones that you can just weld on. Other than that steering trackbar springpad and brake lines need to be modified.
1 - 2 of 2 Posts
