Pazuzu said:I will recommend Roger Browns lifts, mine should be on my porch as we speak
Here's the page:
4Crawlr's page
His lifts are basically custom, tell him what you want, what material, what size, what hardware, it'll come that way. I payed $137 for the 2 inch lift and poly bushings, good materials...
What you meant to say.toy4crawlin said:I will use those.
But true, go with he Brown!!!!!!!Kyron said:Another happy customer here too![]()
You cant go wrong with Brown .................. (damm thats dumb :flipoff2: )
Dude...what's the difference between your cab riding on stock body mounts or aftermarket ones that are an 1" or so taller?tuckn18s said:Here is what you want to do. Buy your body lift but don't brace it where the body lift spacers meet the cab. Then while you are out wheeling you here at slight creak and then suddenly you are sitting at a slight angle. Get out to check it out and find out that the body lift the previous owner had put on was such a hack job that on one side of the cab, the spacers actually went through the floor board, thus making one side of the body body-lifted and the other side not. In the process, the fenderwells in the engine compartment crack where they meet the firewall. That being said, I have never cared for body lifts since.
Performance Accessories has always delivered bad kits (for other vehicles) on all the ones I've seen....about 6 kits. Missing parts, wrong parts, too many parts, no instructions, etc.I have always used Performace Accessories body lifts without problems. Like $65 or $70 bucks. I never knew about Rogers body lifts....
jrussell said:
Dude...what's the difference between your cab riding on stock body mounts or aftermarket ones that are an 1" or so taller?Even if you don't have a body lift, you still have the same components on your truck. It was the installtion you had a problem with, not the body lift.
Man we don't care. The question was "WHAT BODY LIFT SHOULD I LOOK FOR?" Not how did the previous owner of your truck screw you over.tuckn18s said:Maybe I didn't explain my story quite clear enough. Mind you.......the body lift was 3 inches! The spacers were present under the front mounts, spacers present on passenger side, spacers all the way through the floor on the driver's side! I don't know what you are thinking, but that puts some stress on the cab (enough to do some cracking) Didn't I mention that the previous owner installed the body lift? Yeah I think I did
Roger Brown is the man....I've got his 2" BL and it was flawless. Hardware can be upgraded for minimal costs. And he even coated my pucks BlackSeriously though, wouldn't you rather support someone who actually spends the time to develop good products for Toyotas?? Keep the faith in the bloodline. :flipoff2:
