1 - 12 of 12 Posts
I got a chevy 350 im going through and i was thinking about changing the cam bearing and the cam, among other things. the engine is in pretty good shape (around 40k miles on it)
but alot of people make a big deal about changing the cam bearings and saying the tool is $$$. ive found a chevy sb cam bearing tool for $60.00 and im pretty good at working on this sort of thing what do you all think?
putting cam bearings in a chevy is a peice of cake. and all those poeple telling you its big $$$ are the reasons machinists charge so much.
yeah everyone also says "oh be careful to go real slow so you don't nic a cam bearing" blah blah blah......ask any competant machinist, you won't get a cam in without a little nic of a bearing, just don't be a jackass and hit it in with a hammer (I have actually seen this).
-Scott
Only 40k? Don't bother changing them. The ONLY time I ever heard of people actually changing cam bearings (worked in a Chevy dealership for 5 years, dad was a Chevrolet Master Technition for 48 years) is if the block had been hot tanked, the chemicals don't do the bearing material any good.
is the tool for cam bearings generic or brand specific? i.e., could i use a chevy bearing installer on an AMC?
i got a quote for cam bearings for $120 from a local machinist. that's if i bring in the short block, already cleaned.
If you got a access to a lathe or anybody owes you favors I can give you a print and you can make your own bearing installer or if you wanna pay shipping I'll build that shit for ya.
Discussion Starter · #9 ·
I take it that means not even if your changing the cam? cuz i think i might get a new cam and i have some new clevite 77's on hand for it.
I've never heard of anyone changing cam bearings just for a cam swap, if your motor is worn enough to need cam bearings your main/rod bearings would be long gone. There is little load and little wear on came bearings.
1 - 12 of 12 Posts
