1 - 18 of 18 Posts
Super Moderator
'82 Scrambler, '14 Rzr
flimmy said:
BINGO, looks like the shaft would pull apart as soon as that side drops down.
I only see about 1.5" of spline showing... if any less shows, it would bottom out on compression
Chrisf said:
I agree with that
Ditto here too. I'd shoot for even more than that showing at rest... that's why a long-travel slip joint of some sort is needed, which that one is not.
Discussion Starter · #14 ·
If thats enough slip then why does Jess sell the long slip shafts ? Looks like 7" of slip tops if you go by DRM's 1.5" of spline showing. And with Alcan springs I think they may flex enough to pull the shaft apart.
1 - 18 of 18 Posts
