How wide?
  • >70"
    Votes: 2 2.8%
  • 70-74"
    Votes: 5 6.9%
  • 74-78"
    Votes: 21 29.2%
  • 78-82"
    Votes: 22 30.6%
  • 82-85"
    Votes: 8 11.1%
  • 86+"
    Votes: 14 19.4%
1 - 13 of 13 Posts
Well, I'd be pretty excited if I could fit into the pile of 34" jeans in my closet. :flipoff2:
Personally, I just wish my rig was skinnier, I'm at around 88" sidewall-sidewall now and it works good for me.
Pete
i like 88 or better, i have to back up some but it feels so much better on the side hills, i love it. but my rig is tall and long. a comp rig has to fit, so it would be much narrower than i am. but for a trail rig, wider is better for my area. mike
Wider= more stable. So in I think it is clear that wider is better. My rig was at 92 before!! I Loved it and of course I was wide as hell but around here it worked sooooo well. I could side hill most places where some guys where having trouble going straight up.
Personally, 74" - 76" is just about right for my XJ. I'll be dropping in a Ford F-150 HP44/ 9" with 37s on 15x8s with about 4.5" of backspacing. Stock XJ/ TJ/ ZJ wms width is 60.5, so once you grow out of 33s, the axles are simply too weak and too narrow. My desired width should keep the 37s snug, yet have an aggressive stable stance; should work out nicely.:D
Anyways, thats my $.02 worth.:flipoff2:
In a freindly way, I call BULLSHIT! Up here, ideal width would be 60-70 inches! I was at 88" as well, and it cost me a few nights on the trail several times over! The reason I say Bullshit, is that I think it is a common misconception that wider means you won't flip. In my areas, it just means the wide trucks have to go that much higher up the side of cliff walls, because the walls are 14' tall, and 80" apart at the widest part of the trail! Ever seen a 7 foot tall truck on its door in an 8 foot wide hallway? We just had to drag it on its side for 40 yards and keep swapping batteries. Looooong day.
i loved 84" on my old jeep, but i cant go that skinny on the dodge. i'm shooting for under 90" with the 18" wide boggers.;)
wide = stuck on tight trails. there are some trees only 90 or so inches apart and theres no way around. hopefully the body will get shrunk down a little as i go also. :D
Discussion Starter · #11 ·
Just as an FYI for ya, my power wagon is at 79".. and i have a feeling i am going to get my 4 runner around the same width.
Garrett
Right now my width is 72" which I find a little too narrow and unstable in my top heavy Explorer. It can be very un-nerving especially since I went to 36's a year ago. I am going to full width axles and with my current tires I should end up around 80" or so. I don't want to be freaky wide but I would like a little more stability. Also plan on dropping a few hundred pounds off my truck as well.
1 - 13 of 13 Posts
