1 - 6 of 6 Posts
I have axles from a 83 toy truck for my Samurai. I plan to install 1.5 inch wheel spacers because I did not check and bought wheels with 4 inch b/s. The studs on the front axle only measure 1 inch from the hub. Are there studs available that are a little longer without going with 1/2 inch?
Thanks, JC
Thanks, Do I need to drill to install the 1/2 inch studs? JC
I have metric in the rear and standard in the front. Its really not that big of a deal. Just keep your lugnuts separate front and rear. Better than having to drill for 1/2".
Thanks, JC
If i read what you asked correctly. You don't have to have studs that are the same length as the spacer. The spacers have new studs in them.
1 - 6 of 6 Posts
