1 - 9 of 9 Posts
Dinkerdoodledoo
I took today and tomorrow off...
Lurking since 1956
Things should start picking up, the coding for the admin to add the stuff plus getting the database set up takes a while after that things go pretty quick.
Lurking since 1956
You can pretty much make all the things in the game now, cities, shops, items, and rigs. The only thing you can't do right now is add the item to a shop which will be up in sort time. We still need to get the house table done but that will be done shortly also. It won't be long now until we are ready to test. There's a lot of work there for you. I have some of the rig pics now but we'll need some more. There probably should be at least 5 rigs in each class so not as many people are using the same rig. We can make more rigs for the class as we go also as more people start playing. You could also have a custom rig in the donator packs, pay say $5 and get your own rig after so many classes completed which would include a custom pic by the user or we can pick one for them. You'll have more work once we get the trail rides and the comps done.
Lurking since 1956
Ok, everything you need to set up the game should be up and working. I'll be making 2 of each for us to use for tweaking the wheeling trips,comps pages as well as others that depend on stats. We will ad rig pics when we get the profile page up.
Lurking since 1956
We're making a lot of progress shouldn't be long now:D Just some FYI, this game will have the best admin panel of any game template to date, we are making scripts to add a lot of things through the admin panel so you don't have a lot of Data Base mods. In short, we're dumbifying it. This is a whole new code that we will use for our new template design. The admin page is over 4000 lines on it's own. We'll be ready for testing real soon.
Lurking since 1956
The game will most likely be ready for this weekend if everything goes right. Most of the admin works, users, friends, enemies, the rules and FAQ pages are up. I'll copy the rules from the other one for now and I do a FAQ for you to start out with. I'll ad as many chances for the wheeling trip as I can some up with now and you can add them as you think of them as you go. Once we start testing we can get some help from the people who test maybe. You can start getting people to test, we are close.
We did have the Pirate header in but took it back out for now so that works also. We will most likely move the menu to the other side and match the left side menu from the header Lance posted. This means we lose your rig in the header though. You can make a different header later if you choose, I can make you that part of the jpg over to fit in the code you have and just change the jpg name for the game.
Hey lance or john whoever feels like helping me in this case.
i actually need the code to the header instead of the file to include im having some errors poping up due to double sniplets of code and what not since i need to have the code put css and javacsript into the header which you have setup so thats kinda a problem.
got a few more pages up this morning.
anyways yeah if u can get me that that would be awsome!
Bummer we can't call the templates. Here's the code.
Top code -
PHP:
<html>
<head>
<title>Pirate4x4.com - The largest off roading website in the world.</title>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
<style type="text/css">
body {
	background-color: #000000;
.style1 {	color: #FFFF00;
	font-weight: bold;
.style2 {	font-size: x-small;
	font-style: italic;
</style>
<script type="text/JavaScript">
function MM_preloadImages() { //v3.0
  var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
    var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
    if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_swapImgRestore() { //v3.0
  var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_findObj(n, d) { //v4.01
  var p,i,x;  if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
    d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
  if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
  for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
  if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_swapImage() { //v3.0
  var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
   if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
<link href="arialstyle.css" rel="stylesheet" type="text/css">
body,td,th {
	color: #FFFFFF;
a:link {
	color: #00FF00;
a:visited {
	color: #FFFFFF;
a:hover {
	color: #FFFF00;
a:active {
	color: #FFFF00;
</style>
<script src="http://www.google-analytics.com/urchin.js" type="text/javascript">
</script>
<script type="text/javascript">
_uacct = "UA-1092122-1";
urchinTracker();
</script>
</head>
<body leftmargin="0" topmargin="0" marginwidth="0" marginheight="0" onLoad="MM_preloadImages('/images/rev2/side_menu2_02.gif','/images/rev2/side_menu2_03.gif','/images/rev2/side_menu2_04.gif','/images/rev2/side_menu2_05.gif','/images/rev2/side_menu2_06.gif','/images/rev2/side_menu2_07.gif','/images/rev2/side_menu2_08.gif','/images/rev2/side_menu2_09.gif','/images/rev2/side_menu2_10.gif','/images/rev2/side_menu2_11.gif','/images/rev2/side_menu2_12.gif','/images/rev2/side_menu2_13.gif')">
<!-- ImageReady Slices (pirate header.psd) -->
<table id="Table_01" width="100%" height="123" border="0" cellpadding="0" cellspacing="0">
	<tr>
		<td width="14%" background="/images/rev2/pirate-header_test.gif">
			<a href="/welcome1.php"><img src="/images/rev2/pirate-header_01.gif" alt="" width="418" height="123" border="0"></a></td>
		<td width="68%" background="/images/rev2/pirate-header_test.gif"> </td>
	  <td width="18%" valign="top" background="/images/rev2/pirate-header_test.gif"><table width="100%" border="0" cellspacing="0" cellpadding="0">
        <tr>
          <td><div align="right"><img src="/images/rev2/banner_space_01.gif" width="507" height="36"></div></td>
        </tr>
        <tr>
          <td><table width="497" border="0" align="right" cellpadding="0" cellspacing="0">
            <tr>
              <td width="2%"><img src="/images/rev2/banner_space_02.gif" width="5" height="60"></td>
              <td width="65%">
<!--/* Openads Javascript Tag v2.3.37-beta */-->
<!--/*SSL Delivery CommentSSL Backup CommentComment
<script type='text/javascript'><!--//<![CDATA[
   var m3_u = (location.protocol=='https:'?'https://p2.pirate4x4.com/www/delivery/ajs.php':'http://p2.pirate4x4.com/www/delivery/ajs.php');
   var m3_r = Math.floor(Math.random()*99999999999);
   if (!document.MAX_used) document.MAX_used = ',';
   document.write ("<scr"+"ipt type='text/javascript' src='"+m3_u);
   document.write ("?zoneid=3");
   document.write ('&cb=' + m3_r);
   if (document.MAX_used != ',') document.write ("&exclude=" + document.MAX_used);
   document.write ("&loc=" + escape(window.location));
   if (document.referrer) document.write ("&referer=" + escape(document.referrer));
   if (document.context) document.write ("&context=" + escape(document.context));
   if (document.mmm_fo) document.write ("&mmm_fo=1");
   document.write ("'><\/scr"+"ipt>");
//]]>--></script><noscript><a href='http://p2.pirate4x4.com/www/delivery/ck.php?n=afd9319c&cb=982348237320202378385' target='_blank'><img src='http://p2.pirate4x4.com/www/delivery/avw.php?zoneid=3&cb=982348237320202378385&n=afd9319c' border='0' alt='' /></a></noscript>
			  </td>
              <td width="33%"><img src="/images/rev2/banner_space_04.gif" width="34" height="60"></td>
            </tr>
          </table></td>
        </tr>
        <tr>
          <td><div align="right"><img src="/images/rev2/banner_space_05.gif" width="507" height="27"></div></td>
        </tr>
      </table></td>
	</tr>
</table>
  <tr>
    <td width="7%" height="430" valign="top" background="/images/rev2/pirate-sidemiddle.gif"><table width="100%" border="0" cellspacing="0" cellpadding="0">
      <tr>
        <td><table width="44%" border="0" cellspacing="0" cellpadding="0">
          <tr>
            <td><img src="/images/rev2/side_menu_01.gif" width="199" height="57"></td>
          </tr>
          <tr>
            <td><a href="/adindex.php"><img src="/images/rev2/side_menu_02.gif" name="adindex" width="199" height="24" border="0" id="adindex" onMouseOver="MM_swapImage('adindex','','/images/rev2/side_menu2_02.gif',1)" onMouseOut="MM_swapImgRestore()"></a></td>
          </tr>
          <tr>
            <td><a href="/forum"><img src="/images/rev2/side_menu_03.gif" alt="bb" name="bb" width="199" height="20" border="0" id="bb" onMouseOver="MM_swapImage('bb','','/images/rev2/side_menu2_03.gif',1)" onMouseOut="MM_swapImgRestore()"></a></td>
          </tr>
          <tr>
            <td><a href="http://pirate4x4.mail.everyone.net/email/scripts/loginuser.pl"><img src="/images/rev2/side_menu_04.gif" alt="email" name="email" width="199" height="17" border="0" id="email" onMouseOver="MM_swapImage('email','','/images/rev2/side_menu2_04.gif',1)" onMouseOut="MM_swapImgRestore()"></a></td>
          </tr>
          <tr>
            <td><a href="/opinion"><img src="/images/rev2/side_menu_05.gif" alt="ed" name="ed" width="199" height="16" border="0" id="ed" onMouseOver="MM_swapImage('ed','','/images/rev2/side_menu2_05.gif',1)" onMouseOut="MM_swapImgRestore()"></a></td>
          </tr>
          <tr>
            <td><a href="/pr"><img src="/images/rev2/side_menu_06.gif" alt="news" name="news" width="199" height="18" border="0" id="news" onMouseOver="MM_swapImage('news','','/images/rev2/side_menu2_06.gif',1)" onMouseOut="MM_swapImgRestore()"></a></td>
          </tr>
          <tr>
            <td><a href="/legal"><img src="/images/rev2/side_menu_07.gif" alt="legal" name="legal" width="199" height="19" border="0" id="legal" onMouseOver="MM_swapImage('legal','','/images/rev2/side_menu2_07.gif',1)" onMouseOut="MM_swapImgRestore()"></a></td>
          </tr>
          <tr>
            <td><a href="/link"><img src="/images/rev2/side_menu_08.gif" alt="links" name="links" width="199" height="17" border="0" id="links" onMouseOver="MM_swapImage('links','','/images/rev2/side_menu2_08.gif',1)" onMouseOut="MM_swapImgRestore()"></a></td>
          </tr>
          <tr>
            <td><a href="/merchandise.php"><img src="/images/rev2/side_menu_09.gif" alt="mechandise" name="merch" width="199" height="18" border="0" id="merch" onMouseOver="MM_swapImage('merch','','/images/rev2/side_menu2_09.gif',1)" onMouseOut="MM_swapImgRestore()"></a></td>
          </tr>
          <tr>
            <td><a href="/gallery"><img src="/images/rev2/side_menu_10.gif" alt="gallery" name="gallery" width="199" height="18" border="0" id="gallery" onMouseOver="MM_swapImage('gallery','','/images/rev2/side_menu2_10.gif',1)" onMouseOut="MM_swapImgRestore()"></a></td>
          </tr>
          <tr>
            <td><a href="/articles/productreviews"><img src="/images/rev2/side_menu_11.gif" alt="reviews" name="reviews" width="199" height="16" border="0" id="reviews" onMouseOver="MM_swapImage('reviews','','/images/rev2/side_menu2_11.gif',1)" onMouseOut="MM_swapImgRestore()"></a></td>
          </tr>
          <tr>
            <td><a href="/tech"><img src="/images/rev2/side_menu_12.gif" alt="tech" name="tech" width="199" height="18" border="0" id="tech" onMouseOver="MM_swapImage('tech','','/images/rev2/side_menu2_12.gif',1)" onMouseOut="MM_swapImgRestore()"></a></td>
          </tr>
          <tr>
            <td><a href="/trailreports"><img src="/images/rev2/side_menu_13.gif" alt="reports" name="reports" width="199" height="17" border="0" id="reports" onMouseOver="MM_swapImage('reports','','/images/rev2/side_menu2_13.gif',1)" onMouseOut="MM_swapImgRestore()"></a></td>
          </tr>
          <tr>
            <td><img src="/images/rev2/side_menu_14.gif" width="199" height="137"></td>
          </tr>
        </table></td>
      </tr>
      <tr>
        <td background="/images/rev2/pirate-sidemiddle.gif"><div align="center">
		 <script type="text/javascript"><!--
google_ad_client = "pub-9487288772798986";
google_alternate_ad_url = "http://www.pirate4x4.com/banners/superiorvert3.jpg";
google_ad_width = 160;
google_ad_height = 600;
google_ad_format = "160x600_as";
google_ad_channel ="";
google_color_border = "003300";
google_color_bg = "333333";
google_color_link = "00FF00";
google_color_url = "00FF00";
google_color_text = "FFFFFF";
//--></script>
          <script type="text/javascript" src="http://pagead2.googlesyndication.com/pagead/show_ads.js"></script>
		</div></td>
      </tr>
    </table></td>
    <td width="92%" valign="top" bgcolor="#000000"><table width="100%" border="0" cellspacing="0" cellpadding="8">
      <tr>
        <td>
Bottom code -
PHP:
		</td>
      </tr>
    </table>
    </td>
  </tr>
</table>
  <tr>
    <td width="14%"><div align="left"><img src="/images/rev2/bottom-cap.gif" width="198" height="61"></div></td>
    <td width="72%"><div align="center">
   document.write ("?zoneid=61");
//]]>--></script><noscript><a href='http://p2.pirate4x4.com/www/delivery/ck.php?n=ab0bb17c&cb=349857345043034534767764' target='_blank'><img src='http://p2.pirate4x4.com/www/delivery/avw.php?zoneid=61&cb=349857345043034534767764&n=ab0bb17c' border='0' alt='' /></a></noscript>
    </div></td>
    <td width="14%"><img src="/images/spacer.gif" width="198" height="61"></td>
  </tr>
</table>
<table width="100%" border="0" cellpadding="0" cellspacing="0" background="/images/rev2/pirate-footer-tile.gif">
  <tr>
    <td width="2%" height="122" background="/images/rev2/base-tile.gif"><img src="/images/rev2/pirate-footer-left.gif" width="53" height="122"></td>
    <td width="96%" background="/images/rev2/pirate-footer-tile.gif"><div align="center"><img src="/images/rev2/pirate-footer.gif" width="905" height="122"></div></td>
    <td width="2%" background="/images/rev2/base-tile.gif"><img src="/images/rev2/pirate-footer-right.gif" width="53" height="122"></td>
  </tr>
</table>
<!-- End Pirate4x4.com -->
</body>
</html>
1 - 9 of 9 Posts
