1 - 8 of 8 Posts
Bought an engine from j20mark and i have no friggin idea what year it is. Since he isn't returning my calls i come to you. What i need is a locations of numbers so i can post them and have them deciphered for me. I need this for several reasons. Finding the right oil filter, need to get the right dipstick press in rod for the block and timing stuff. Help me out please.
There are no ID numbers cast or stamped into the block itself, aside from the big "360" cast into the side of the block under the motor-mounts.
The ID tag was screwed to the front of the passenger-side valve-cover. Needless to say, what's on there is not always related to what the engine came out of.
That figures, AMC must not have thought that someone may need to replace a valve cover. I took out a 360 from my 87' grand waggy and the block i put in needs an oil dipstick tube. ( the one that presses into the block. The one from my 87' is too small in diamiter and is broken anyway. Any place i could pick one up that is the size i need? Thanks for the help.
Dipstick tubes are still available from the dealer for under $10. Are you sure that the old one is completely out? Maybe see what year the part-numbers changed, and order the earlier one. I'm guessing that any change would have occurred with the '79 model year, so maybe see if a '78 or earlier application calls for a different number.
Good luck finding a dealer who would work with you on this one.
1 - 8 of 8 Posts
