1 - 6 of 6 Posts
i need to run a wire to ignition switch from my painless 5.8l engine harness.
its the wire that gives juice to the whole engine and fuel pump.
does anyone know where i should run it and if anyone has a pinout or wiring diagram for the ignition switch im sure that would help
Garb your multimeter, you will find that there is a red wire in the 4 wire connector on the drivers side under the hood that is switched power. I'd tell you which one it is, but the tracer is long worn off on my truck.
I'd use it to switch a relay if that isn't what the painless harness is going to use it for.
the painless kit already has a a relay for the fuel pump and eec .
so should i wire it to the light blue wire in the ignition switch
1 - 6 of 6 Posts
