1 - 10 of 10 Posts
I am looking for somewhere to buy a tubing bead roller. I have also heard then called a "donkey d!cker". It rolls a bead on the end of a piece of tube so when you put a hose and hose clamp over it it will not slide off.
Thanks,
Dan
IH/Rover Moderator
papee said:
If your talking about a flaring tool you can get it at just about any hardware store.
:rolleyes: :rolleyes:
Damn, you are quick! Thanks for the help. $150 isn't too bad...
The only other thing I could find were these from Earl's but I would have to buy one for each size of tube. I think they are about $30 each.
IH/Rover Moderator
The Earls one is fine you only want to use small aluminum tubing.
If you have a bender................................
I bet you could make a few $$ making up custom water pipes for the guys that want to mount a radatior in there bed!
rodzzilla said:
Would a cheap-o HF bead roller($90) for flat panels be able to do the same thing? I have one, but haven't tried using it on tubing.
It will if you have the dies sized to your tube
This is what I use.
Quite a bit more money then the HF roller but it will last a lifetime .
For doing small tube1/4" to 1" a set of parker beading tools can't be beat and you can find them on ebay at times under aviation tools.
rich
1 - 10 of 10 Posts
