1 - 12 of 12 Posts
thhhpptthh!
damn i've serached through alot of google search crap and found nothing.
Where have you all found secondary PS resevoirs at? I was hopeing to find a finned aluminum one for some cooling dutys.
Nate.
thhhpptthh!
so next stoopid question.
With this ram, is it necessary to run hydraulic oil, or can i run PS fluid, or are they the same thing???
lol
nate
edit: just ordered this cooler.. should add more than enough extra fluid for me.
Thanks again for the links OS
Old Scout said:
Hey,
That cooler/filter setup in the pic is made by my neighbor, Fred Appleton. He runs Appleton Power Rack and Pinion. You can buy directly from him at: 815-467-1175. He's located in Minooka Illinois which is about and hour southwest of Chicago.
I'm running the same setup on my Jeep right now. Easy install, clean setup.
edit: Here's a link to his website:
http://www.appletonrackandpinion.com/Coolers .0.html
thhhpptthh!
lt1yj said:
Hey,
you get a neighbor discount??? ;)
I already ordered the one i linked above, but i would gladly return it in favor of that one.. its just a tad outta my budget at the moment
Station...
Has a nice unit, with a filter and pressure gage so you can monitor the filter maint- very affordable- is your 5.2 Jeep almost done?
thhhpptthh!
Discussion Starter · #10 ·
Re: Station...
almost done, gittin down to the nitty-gritty now.
to-do list that i carry with me sayyyyyyys......:
-mount orbital
-plumb steering
-replace PS pump
-install fuel cell rollover valve
-install tranny cooler
-create exhaust
-skid plates
-gauges
-bump stops if ness.
-bolt winch back on
-finish paint
-install shift kit
-install bearings on rear spare axles.
hopefully can have this done in the next few weeks.... we're heading to AZ on the 25th of feb and i want some test time in before we go.
$150! I made my own out of some aluminum tubing and some scraps of aluminum plate for about NOTHING! Gotta love being a machinist :D Mine will hold about a quart and a half. I just need to drill and tap for the AN fittings, plumb it in, and Hydro a 60 to put under my Flatfender. :D
1 - 12 of 12 Posts
