1 - 11 of 11 Posts
Where do you measure the castor to get the correct angle on a front axle? It's a D60 from a 79 F350 if it matters. I'm putting coilovers on with some twister arms. I can adjust after I've welded the brackets in place but I'd like to start with it at about 2 degrees. So, where do you measure from??? <IMG SRC="smilies/beer.gif" border="0">
hows it go? angle of the dangle is the cube of the boob less the mass of the ass <IMG SRC="smilies/wink.gif" border="0">
its the angle through the steering joints.
both joints aligned vertical = zero caster. upper joint rearward of lower joint = positive caster
is this enuf?
Actually I was wondering where you physically measure from. I know it's thru the axis of the knuckle but not quite sure how to measure it there. I thought maybe take the angle flat against the yoke, but I don't know if that's the same. And I don't know if the leaf pads were welded on exactly horizontal(or what would be 0 castor). See what I'm sayin
If you don't want to be percise measure it any where you want, but remember two don't equal three..... <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0">
Get a magnetic Universal Protractor from Sears On-line. They are $9.99. Put it on the back side of the knuckle on the housing. Measure there. Rotate to where you think it is good and measure again.
Just my $0.02 but I am never right so there you have it! <IMG SRC="smilies/thefinger.gif" border="0">
[ 09-07-2001: Message edited by: SweetCJ7 ]
Measuring the angle through the balljoints will get you very close to the caster measurement, but not exact. Close enough for our purposes. But FYI, it isn't actually caster, it has to be calculated from a host of other measurements...
--Rob
Discussion Starter · #11 ·
I found the angle finder at home depot for about 10bucks. This isn't a daily driver so it doesn't need to be perfect but I would like to be able to drive it around. So, I just measure the angle from horizontal off the top of the knuckle right? and set it around 2 and then adjust. For some reason I was thinking I needed to know what the pinion angle was on the axle in the F350?
1 - 11 of 11 Posts
