HD60? AKA dana 61?desertCJ said:Dana 70 and HD Dana 60![]()
30 spline the same size as a 60 35 splineWillyPete said:maybe nobody mentioned the 14 bolt cuz they're actually 30 spline...
Are you sure about this? I"m pretty sure that if it has 30 spline shafts then it isn't a HD Dana 60, just a standard 3/4 ton full floater. I think that if it has 30 spline shafts in front(D44) then it will have 30 spline rear shafts. 35 spline front end and it has 35 spline rear unless it's a chevy then it has a 14 bolt.Also, as a side note, almost every HD60 that you find will have 30 spline shafts.
yeah i know, 1.5" coarse spline and all that. but he asked for 35 spline FF shafts... ergo, 14b does not fit the bill.DRM said:
30 spline the same size as a 60 35 spline![]()
Siiiiigh :shaking:NEwbie said:Are we so quick to forget that the 35 spline GM 14 bolt 10.5"....
