I had this little adventure (see below) with my new Warn 16.5TI and came to the conclusion I probably ought to go ahead and upgrade the batteries now.
What's the consensus on the OPTIMA® Batteries 8014-045 D34/78 YELLOWTOP® Starting & Deep Cycle?
Is it really worth $200? (of course, I need 2x of them, so $400!)
Is there a more appropriate battery on the market?
A vendor I should support?
Thanks in advance.
A few years ago this giant oak tree was casting a shadow on the pool, so I figure why not hire a tree guy to 'prune' it.
Well, butcher was close to the truth, then after another haircut to trim it up it...died. So sad, so sorry.
Anyway, what to do with said giant dead oak tree? Chainsaw time. :cheers:
Here's the youtube of it coming down. Cutting down a big Oak Tree - YouTube
Then we chopped it up but saved some of the bigger pieces to carve benches and chairs (again with the chainsaw.) The biggest of which I figured I'd drag over to a nice flat concrete pad I had to work on it. We latched onto it with the truck and it was a no-go. Wouldn't budge. Snapped a few chains before we came to the conclusion it was still too big. So we worked those little chainsaws and made even smaller chunks of giant tree.
Now it is time for the Superduty and the winch to get a workout.
Hauling cable. I have a synthetic upgrade in the shop
Hooked up and ready to pull
I definitely underestimated even the size of what was left of this log. Dang thing is HEAVY. Truck can't pull it, but if I dig in, set the brakes and winch it'll drag the log. I will note that sustained hard pulls like this will require a high idle, I dragged it a good 60' with the winch.
Some video Superduty with SuperArmor and a Warn winch moving a huge log - YouTube
Once I got it up out of the main yard I hooked up my trusty 3"x30 strap and launched the truck into the traces again, with a good launch I was able to get the log moving and managed to drag it over near the concrete pad. I had a little trouble getting it maneuvered in between the trees and ended up having to re-position a couple times and winch it back into a path it could take.
SuperArmor & Ford Superduty VS Giant Log - YouTube
The sound you hear at the end of this video is the strap snapping when I gave it a 10' run. And that was the end of that fun.
Turned around, hooked up the winch and proceeded to drag the truck. OK, then, not going that way.
Back with the winch to maneuver the log off the chain and position it so I can cut it's base. Once I do that I'll roll it again with the winch up on the pad.
The Superduty did it's job today and worked hard. I really like this wireless controller too.
Then we went downtown Greenville for dinner.
Thanks in advance.
