1 - 20 of 42 Posts
I'm researching doing a triangulated 4 link in the rear of TJ. I'm planning on using the big RE super-flex joints at the frame ends, and the M.O.R.E. bushings at the axle ends. Will these give the links sufficient range of motion?
Thanks guys.
Hey Vols, It looks like you used square tubing for your links front and rear. What did you use size wise and how are they holdin up.
I use the RE spherical joints on one end & their new soft poly bushings on the other & it's great.
2x2x.250 tubing -- used the flex joints at the triangulated ends of both the uppers and lowers --- bushings at the wider ends
ask me in a few months how it's holding up -- haven't had it on the trail yet....but I think it'll hold up at least as good as than anything else out there.
we've installed the Clayton kit -- it works great -- mine picture above is not a Clayton kit, but I will say that I certainly learned what I could from his design...and then adapted it for double-triangulation (look at my buddy's hand througth the spring and you will see the angle/location of the lower links), 113", and a 3-link front
here's the Clayton single triangulated installed in a TJ
Discussion Starter #12
So the question remains, which joints at which ends? I like the RE joints for the range of motion, and the MORE rubber bushings for the cushioning. So which joints at which ends? We're talking plain old vanilla triangulated long-arm 4-link folks.
I will have a very similar set up to Vols with the exception of running the large RE joints front and rear on the links. I too am using 2x2 .250 wall square tubing. I'll break a link before I bend that shiat, and its heavy so I'll have some more weight down low. Look for a tread next week on the build up, Astar and I are doing it.
I wanted a suspension that would not bind. I also wanted to run bushings on one end to save money...I drew it up in autocad and the setup I had was gonna bind unless I used some sort of joint on each end. So I am running 2.5" Johnny Joints...threaded on one side non threaded on the other...a pic.
lower links are 1.5" .250 DOM sleeved with 1.75" .120 DOM
uppers are just 1.5" .250 DOM
I used JJ's at the triangulated end (i.e., at the axle truss where the links are closest) - can't tell you that it is THE best place, but I can tell you that I have absolutely no binding issues
CA YJ -- nice looking work
I'm actually getting ready to stretch my TJ and I'm using Heims at both ends of all the links. I don't think there's any chance of binding.
I used heims at both end when I made the double triangulated setup on my CJ6. When it was done I could see that it was not necessary. I likely did not need anything but bushings or rubber mounts. I keep my coils captured though. If you keep the links in line with the mounts, there is very little bind at all. With a bushing on one end and some type of flex joint on the other, you should be fine.
If I was going to use a bushing at one end, it would be at the frame side.
I used RE joints on one end of my lowers and the big Skyjacker heims on the other. I used all 3/4" hiems on my uppers, and an 1 1/4" heim at the axle end of my A arm in for my front 3 link.
1 - 20 of 42 Posts
