1 - 7 of 7 Posts
so i picked up a 350 four bolt main today and i'm trying to decide which heads to use; the heads that were bolted to the block or the ones i have in the garage.
the engine block casting # - 14010207
option 1: a pair of "camel hump" w/ 62 cc chamber, casting# 3782461
option 2: a pair of 76 cc chambers off a '75 'vette, casting# 333882
how would the changes in chamber size affect the engine?
The 62 cc would create a higher compression. The 76 cc heads are going to be smog garbage heads. I would run the double humps. Actually I do run those exact same heads.
if they are early "double hump" "camel hump" heads, they probably dont have hardened seats, for use with unleaded gas. they also probably dont have accessory bolt holes for attaching things like alternators, power steering, air conditioning. These things can be attached, using aftermarket parts that cobble it together.
I would use the 882 casting, as it is almost as good, but it has a larger chamber and does have accessory bolt holes. it might even have hardened seats.
why bother with either, though? youre gonna spend more money trying to cobble them together than you would if you bought new parts. rebuilding a set of heads can easily run 400-600 bucks. new heads, vortecs, run 600 bucks complete and ready to bolt on, and flow more, too.
just an idea.
Supposedly the Vortec heads 96 and up flow as good if not better than the stock double humps. You will need a Vortec specific intake with vortec heads.
They are well worth it!
1 - 7 of 7 Posts
