another thing you have to consider that the cruiser t-case is a passenger rear output, and down low. the 205 is a center rear output ant the same level as the input shaft. that's a good 8 inches higher and will increase your driveline angle a lot! 205's also weigh about 2 times as much as a cruiser case and they're geared almost exactly 2:1. don't get me wrong, i'm not here to knock the 205's. they are one of the strongest t-cases ever built. but, unless you're running a boatload of horsepower and 1 ton axles with 38's or bigger i don't think you'll need one. <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0">
