1 - 13 of 13 Posts
I have been trying to figure out ways top eliminate my lift blocks. I think that getting lift springs would be the best way, but I dont know what to get. I really liked the Superflex's but they are about 500$. I find springs at Genuine suspension with 4-6" lift for 140 a piece. Are these springs any good? Or should I just do a shackle flip? I have no clue on how those little rivets come out do you just torch them or what? Thanks
Id do the shackle flip. rivets are best removed IMO with a air chisel
Ok I guess I will do that. So you just chisel one end and then hammer it through? I have shitty f 250 leaf springs on their now which is why I figured I might as well get some lift springs. Junkyard here i come
Ramboss429 said:
I just torched the head off of the rivet and used an air chisel to knock it out.
yep that works pretty darn good.
Ok and then what do you do to put em back where you want. Bolt and weld em? Does it matter how far you drop them down? The hangers?
I used grade 8 1/2" bolts to put mine back together.
You can drop the hangers however far you feel like it. I wouldn't go more than 4-5" myself.
you will want to make some new shackles though. The factory ones are too weak for a flipped design. They are only suitable for a tension set up. I will be making mine out of 3/8" steel, or maybe even 1/2". We shall see...
Discussion Starter · #12 ·
Alright cool guys thanks, ill get out and see what I can find.
Franklin said:
F250 shackles will work for ya.
Meh... I recommend building them out of 3/8" steel, but if you really want to buy them, get the F450's...
I have my 350's and I will not be reusing them if you want to send me a shipping label, you can have them...;)
thats a funny smiley :massey:
1 - 13 of 13 Posts
