i am still having some brake issues...
this is on a 91 yj using 1/2 ton chevy calipers in the rear and the dual piston calipers in the front...i also have the 78 mercury marquis with 4 wheel discs and hydroboost master cylinder...
this setup works great but after a little use the brakes begin to lock up and then i have to open each bleeder and release the pressure...
i have heard several theories on this, and will gladly listen to others....
here are my plans...get a new MC..s.ame one under warranty....bench bleed and install
then i am going to take out the little block that comes stock on jeeps and just use a T for the front brakes...
then i am going to put an adjustable valve for the rear....
http://store.summitracing.com/defau...word&searchtype=both&part=proportioning+valve
which one is recommended....any reason to go with the $70 over the standard $40?
then with a good power bleed i should be okay...
thanks, kosta
thanks, kosta
