1 - 4 of 4 Posts
1962 YellowSubmarine
I know there are different speedo gears for the 2WD auto vs manual transmissions, but which does the Transfer Case use? Is it different for different t-cases?
I've got a 205 behind a manual ZF and I just got a cable with the manual speedo gear, is it the right one?
(not worried about the ratio at this point, I just need to plug the hole so I can drive it:D)
:usa:
Discussion Starter · #2 ·
Is this too much tech for you guys? :flipoff2:
or do none of you have a working speedometer?
:confused:;)
:usa:
just for the record, everyone's knowledge, and those in the future that will actually use the search feature -
The ford 205 uses the same speedo gear as the manual transmissions.
:usa:
1 - 4 of 4 Posts
