1 - 10 of 10 Posts
Mine has the number 7802644 stamped on the side. The it also has a number that is 237 on it. Good one?? bad one?
Originally posted by coloradok5:
<STRONG>Yep, you want a 2x4 box, one thing to keep in mind though, the input and output hoses changed from standard to metric some time around the early eighties, can't remember which year off-hand.</STRONG>
Yeah, like Steve said. 2WD box. from 65' to 79' GM used Flare fittings. From 80 and up, they used O'ring fittings. You need a box that uses the same style fitting as your pump. I hear that Flare fittings are better b/c no O'rings to go bad....
<IMG SRC="smilies/confused.gif" border="0"> Who knows though???
Boss
If you do get the differnt box then what you have napa can switch the end coming from the pump. I converted my fitting for $10 or so from o ring to flare.
1 - 10 of 10 Posts
