1 - 10 of 10 Posts
Adam at Rosemont automotive at Keifer/Watt helped me in narrowing my 60. 366-9191
He's got a full-on machine shop and can help with steering also.
SeanP
IronBenderII said:
I have a HP 60 front (kingpin) and I'm looking for somebody to cut and turn my knuckles. Anybody?
Jack
You know what, it is alot easier than you think. All you need is an angle grinder, magnetic angle finders, and new perches. Then have someone weld them.
Does yer dewg bite?
66CJDEAN did mine. He's in Loomis.
Bob Roggy in Diamond Springs...
Welderboy (Bill Rowlette) at Gearman's place off S. Sunrise.
(River City Differential)... 628-9364 (cell)
Both of these do the most excellent work you will find anywhere.
So does Dean out in Rocklin/Loomis?... 802-5337 (I think)
Can't go wrong with any of em... :D:D:D
Re: Re: Who in Sac wants to cut/turn my knuckles?
why perches, he said knuckles..
if you previously had your axle setup for good castor and bad pinion angle, you will need to change your perches as well to get both good.
if you previously had your axle setup for good pinion angle and bad castor, you will not need to change the perches.
Does yer dewg bite?
Technically you only need one new perch since the pass. side is part of the housing and needs to be machined for ideal caster :D
1 - 10 of 10 Posts
