1 - 20 of 41 Posts
What much amperage does the stock alternator put out?
I am running 6 rock lights, 4 large KC lights and a CD stereo with a 200 Watt amp and 2 8" sub woofers, CB radio, etc... <IMG SRC="smilies/confused.gif" border="0">
When I have everthing turned on at the same time the stereo cuts out. <IMG SRC="smilies/eyemouth.gif" border="0">
What is the easiest alternator to install into a relatively stock 22R. I would rather not have to fab up any brackets
Thanks,
<IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0">
Originally posted by woody99:
<STRONG>What is the easiest alternator to install into a relatively stock 22R. I would rather not have to fab up any brackets</STRONG>
Premier Power Welder is a good fit for 22R, the brackets are supposed to need a little grinding to fit the alternator. I have one on my 22RE, and it was a bit more work, but I've seen a 22R instalaltion and the guy said it was fairly esy.
Originally posted by 4CrawlR:
<STRONG>Premier Power Welder is a good fit for 22R, the brackets are supposed to need a little grinding to fit the alternator. I have one on my 22RE, and it was a bit more work, but I've seen a 22R instalaltion and the guy said it was fairly esy.</STRONG>
So about how much is it for the alt? What is the amperage?
thanks,,,
<STRONG>So about how much is it for the alt? What is the amperage?</STRONG>
Link to Premier's web site is on my page, cost and output vary, I have the 160 but it was a lot cheaper when I bought it in '98 <IMG SRC="smilies/eek.gif" border="0">
hey i gots a 85 4 runner with a 22re can i simply bolt on a GM alternator??? please explain how to do this???
Discussion Starter · #10 ·
Originally posted by A_M_J:
<STRONG>I have a 130+ amp marine GM single wire alternator in mine. I had no need for the smog pump so I used the exsisting brackets and it was a direct bolt on.</STRONG>
I wish I could say the same my here it CA you better have it or else...
Got any pics?
OUCH ! ! !
I just got off the phone w/ the guys at www.wranglernw.com . These are the prices that they gave me.
Toyota 85 Nippondenso alternator w/ bracket:
$550 for 140 amp rated (120A hot and 90A idle)
$720 for 175 amp rated (160A hot)
They also have a 110 amp but I didn't ask about a price. He says it is direct bolt in.
Does anyone know of any cheaper options???
Originally posted by Bones:
<STRONG>I think? they are 80 amp stock. I plan on taking mine to a local shop and have it rebuilt and have the amp's upped to 130-140 or so since I just got a winch.</STRONG>
Someone was mentioning this to me a while ago about being able to re-do a stock Alt, any idea what it would cost?
Banned
I had a delco-remy in the nineties, for a meager sum, think it was a little over a c-note, but that was then, and this is now. He brought it from a 60a to a 100a, change of diodes was all that was necessary if i member correctly. Seems easy enough, how come us wrenchers dont know how to do it?
Has anyone done it on thier own?
Discussion Starter · #14 ·
Originally posted by NtheHills:
<STRONG>I had a delco-remy in the nineties, for a meager sum, think it was a little over a c-note, but that was then, and this is now. He brought it from a 60a to a 100a, change of diodes was all that was necessary if i member correctly. Seems easy enough, how come us wrenchers dont know how to do it?
<IMG SRC="smilies/usa.gif" border="0"></STRONG>
Yeah somebody has to have done this before!!!! Come Awn help us out!
I've been running a 90 amp from No Warranties Or Returns (NWOR) which is a rewound stock toyota. Like everything from NWOR it's just someone elses rebadged product. The truck originally had a non OEM alternator that they stuck me with the core charge for. Stock output I believe to be 60 amps for my 82.
Discussion Starter · #17 ·
So if I replace the alternator do I have to replace the regulator? Will a 140amp alt. work fine with the stock regulator?
thanks,,,
Discussion Starter · #19 ·
<STRONG>Internal regulator on the stock unit. My PPW has an external regulator.</STRONG>
Thanks for the info. What is that black box with red that is located on the fender well on the drivers side then? I thought it said regulator on it?
<STRONG>
[qb]Internal regulator on the stock unit. My PPW has an external regulator.</STRONG>
Thanks for the info. What is that black box with red that is located on the fender well on the drivers side then? I thought it said regulator on it?[/QB]
My '85 alternator didn't have that box, maybe it was different in the earlier trucks.
1 - 20 of 41 Posts
