Theoretically Fox does, but it looks like they are actually 18.8" when totally extended.
PN 980-99-120-A and 980-121-A
I swear I have seen a bug with Kings on it, but I have not seen any advertisments. Saw either. Radflow???
I like the FOA shocks but am nailed by the 2" OD only requirement.
Ideas? Sources?
Here is the rule book..
SCR10 Shock Absorbers and Bump Stops
Only one shock per wheel is allowed. Stock front shock mounts must be
utilized. Shock mounting bolts may be changed to a maximum of 1/2 in diameter.
Any manufacture shock allowed with 2.0” maximum outside diameter. Rear
shock must not have an extended length longer than 18”, center of mounting hole
to center of mounting hole. Cooling fins and/or reservoirs allowed. No air shocks
or coil over shocks allowed. No hydraulic bump stops allowed. No bypass shocks
allowed."
(BTW, this is going on a Class 11 off road race bug...)
Ideas? Sources?
allowed."
