Hey Guys,
An appeal to someone more knowledgeable than myself.
I have a 1988 bronco 2, that I swapped in a 1995 351 punched out, stroked out to 392 cu and 10:0 compression.
I didn't like my E4OD/Atlas 2 combo, so I swapped the E4OD for a 1989 AOD transmission.
I have it in the truck, and I start the motor. I put the transmission into gear, but nothing happens. Reverse, Drive, Nada.
I disconnect my cooler lines, and no fluid is going through them at neutral.
This is the AOD, not the AODE. I only have one electrical connector in the side, and it has two wires for starter, two for back up lights, and one for neutral sensing.
What could be up? I can bang through those gears like nothing is connected. Who knows what might be up? The torque convertor went in smoothly, but the tranny is a junk yard find from a local known yard.
Could the pump be completely dead? The fluid was bright red and the filter clean...
Adam
Adam
