1 - 20 of 25 Posts
Who is going?Does any body have an open seat from around Sacramento or Amador county that would let me ride with them?I would take the 84 but can't find a bell housing or flywheel?Any offer please thanks!
We just preran a few of the courses for the Marlin Crawler Roundup this weekend with Randy's Suzuki. He ran the first two easy courses with no problems. We jumped onto the 5th course which is the toughest of them all and it ate him up. Not sure who is willing to get body damage, but if you are, this course is for you.
If you can't drive there, walk there for the fun and hanging out with others.
Here are some pics of this weekend.
See you all there.
-Sam
[ 08-13-2001: Message edited by: Sam ]
yea but sam with a few strategically placed flags even the easy ones can be tough I'd think..
Glad to see ya made it up there! I got all the wires hooked up which means I should be driving Mo right now but I am missing something cause it don't start! Fuel pump is not pumping but when I run it to hot it does pump. It is one of those stupid safety things stoppin me (neutral sensing switch, clutch bypass or whatever, speed sensor, etc..)
[ 08-13-2001: Message edited by: Brandon ]
Originally posted by Brandon:
<STRONG>take a car if ya got one, the event is located a baseball throws away from car parking..</STRONG>
That will be my plan, drive up as far as I can and walk the rest, unless of course I get offered a ride from the spillway! <IMG SRC="smilies/biggrin.gif" border="0"> (Hint Hint...)
Well ,you'll are wellcome to jump in the bed of my truck <IMG SRC="smilies/biggrin.gif" border="0"> II'm camping at the Granite Bowl fri. nite
[ 08-13-2001: Message edited by: Leonel ]
The top two pictures are from course 5 and that thing is BRUTAL!! His Suzuki is tiny and he has already sawzalled the thing to death. After this weekend, he wound up having to take even more off the thing.
So are there going to be any all out screw the dents wheelers? If so, I gotta see you run this simplistic, but tough course.
I hear ya on the flags Brandon. If after the event is done, maybe we could set up a specialty course for the leftover guys and have a best of the best. Lets hook up early and talk about that one.
-Sam
Hey Brandon, you're running a Ford motor and harness right?? My bronco had a "Fuel saftey cut off" switch that would shut the power to the fuel pump off in case of an accident. Only time that stupid thing did shut off was when I pull the power to the CPU.
I AM!! But I don't have a crawler box, I am just going to help Sam and Marlin out. <IMG SRC="smilies/frown.gif" border="0"> DAMN!!
[ 08-13-2001: Message edited by: GloNDark ]
Mike - I was looking for a course just as we had spoke and I think I found one, but not sure if it is what you had in mind. When we meet this weekend, I will show it to you.
Rockcrawla - Now that is the spirit I am talking about. Just don't count on a "little" dent. <IMG SRC="smilies/biggrin.gif" border="0">
-Sam
I should be leaving Marin Co. friday 330-4 ish.It'd be fun to try and hook up w/someone for a "caravan".C.B.,but no radio... <IMG SRC="smilies/biggrin.gif" border="0">Corey.
Originally posted by GloNDark:
<STRONG>Hey Brandon, you're running a Ford motor and harness right?? My bronco had a "Fuel saftey cut off" switch that would shut the power to the fuel pump off in case of an accident. Only time that stupid thing did shut off was when I pull the power to the CPU.
[ 08-13-2001: Message edited by: GloNDark ]</STRONG>
I dunno, I gotta wait till I have have someone turn the key so I can check some things out. Still no power where it is supposed to be coming from for the pump but even if I wire it straight it does not start - but maybe it just needs to be primed. I need someone to watch for spark for me sometime soon. So damn close woohooo!!!
Hey Jess, No problems on the Chevy. Mine is a Willys and it will be there. Then again, it is running mostly Toy running gear. There will be several people there without Toys, however; so you won't be the only one. Besides, you are the man for contributing to the raffle, so you are more than welcome. Thanks again on that.
-Sam
i'm gonna ride up with my dad...sorry only got 2 seats.
i will have a front driveline(highangle driveline of course, thanks jess). but if my crossmember dosen't cooperate with me than i'll only have 2wd.
what channal should our cb's be turned to
happy trails
rich *ruger*
1 - 20 of 25 Posts
