1 - 2 of 2 Posts
So after 4 years I need to replace the calipers on my rear Prorock. And for the life of me I can't remember nor can I find my damn notes on the calipers I got.
In any case I used IFS 1/2 ton front rotors and the wider calipers--from a front 1/2 chev with a metric banjo bolt (10mmx1.5mm). What year did they go to a metric banjo? 80? And if memory serves me right arent the 1/2t & 3/4t calipers the same on the 2wd's?
The only thing that comes to mind would be the 88 and new IFS front calipers. Do you happen to know what the distance between caliper bolts is? If you do, that might help narrow down your search.
1 - 2 of 2 Posts
