1 - 7 of 7 Posts
Cummins 6BT 400HP, NV4500, and upgraded shaft dana 300?
If this T case will die, what would you replace it with?
Current parameters are:
Pass diff dana 60.
Vehicle weight about 5000lbs.
Need a place to pass big exhaust.
Would like more gear options/twin stick.
Currently have 241C Tcase.
Shorter T case length the better.
W.B. 103.5 currently. This can change somewhat.
Consider going to Pass dana 60.
I have a Chevy 205 now that is behind 465 trans. I never had twin sticks on a transfercase. Having them is something that I would like.
The most sensitive issue here is overall drivetrain length.
Putting in a lomax set in the 205 is definately something I would do if I went that route. I will have to go out and measure the 205 as I do not remember what the mounting surface to rear yoke measurement is.
The NV4500 I am using will have all the upgrades as money permits.
My ears are open to other transmission options. As it is, to run this setup I will have to change the diff gears from 4.56 to 4.10. Going non OD poses many other problems overall. Keep in mind I try not to drive like an absolute moron. SO hopefully things will not break for that reason, but I would like to pair things up to at least get a good start before I have to upgrade.
I have a jeep with a 4bt with a sm465 dana 300. The first ride broke the rear output on a small hill. Put in hd outputs now no problem yet. But the 4bt is about 200hp at the most. I would say the 6bt will kill it!
1 - 7 of 7 Posts
