1 - 20 of 51 Posts
Wats up all. Just got myself a Warn M8000. My friend was telling me to get a kill switch for the winch just to be on the safe side, so i decided to do some info on it. Seems like the winch is always on even when the car is off. So my question is how many of you guys are running a kill switch for your winch? I read that i need at least a 450 amp continuous kill switch to not fry the switch. Is that right? Brands and diagrams would be much appreciated. Also I'm open to other ideas as well.
Thanks
Kev
Sent from my SPH-D710 using Tapatalk 2
None. Your friend doesn't know what he's talking about.
It's switched on with the controller activates the relays. By your thinking, your starter is always "on" too.
Super Moderator
'82 Scrambler, '14 Rzr
For what purpose? :confused:
There are ways to make it in-op, but that kind of depends on what your reason is.
IF you hardwire the winch controller to the dash, then it's not uncommon to put an 'on-off' switch next to the 'in-off-out' switch. This prevents an accidental "bump" from activating the switch, which in turn activates the winch.
I've never heard of anyone putting a switch on the main power feed to the winch motor. Because it's already on a solinoid pack, which means that two seperate solinoids would have to BOTH fail, and both fail at the 'on' position. Remembering of course, that when solinoids typically fail, they fail in the 'off' position.
my only thought on what hes talking about is maybe for the main wire... maybe just so encase you get into a accident it doesnt smash into the body and ground out. if thats the case just buy a battery shut off switch like they use on drag cars.
or what about a terminal with a wing nut on it, that way you just disconnect it if you arent going to use it
The above statements are correct. However, I do have master disconnect switches on all my vehicles that don't see daily use. It's somewhat for theft avoidance, but honestly more so I don't walk out to a vehicle that goes "click" after sitting for a few months.
In doing so, I run a battery terminal disconnect so you have to pop the hood and turn the big lever 90-degrees. I run it on the negative terminal and it includes everything connecting to the negative battery terminal, including the winch ground. Required a little more thought with a dual battery setup, but same concept applies.
A main power cut off is a good idea. Although not common.
Most people just hook the power wires for the winch straight to the battery. This is normally not a problem as long as a solenoid doesnt stick.
I've had a winch on every rig for 10 years, and never had that happen... BUT
The last time I went wheelin, the "IN" solenoid stuck on my buddy's winch, he was stuck on a ledge, and I hooked the cable to a tree up on the next ledge (6' vertical). When he started winching, it wouldn't stop... He put the jeep in neutral and jumped out to un plug the winch controller, which still didn't stop the Jeep, so the only way to get the winch to stop was to disconnect it from the battery... Which required popping the hood, and using a 1/2" wrench to "unbolt" the ring terminal from the battery post...
Not the easiest thing to do when the Jeep is creeping towards a 6' vertical ledge with a tree on top...
On my next rig (which the battery is mounted in the cab) I'm going to run the winch power wire through a marine disconnect switch like this: you can get different sizes/ratings. Marine wiring stuff is pretty cool for a offroad rig.
http://www.boatersplus.com/blue-sea...se&utm_content=MM-BS9004E&utm_campaign=google
My dad had a solenoid stick while he was winching himself out on an old warn winch he had on his tractor. Nothing broke but the battery terminal and cable end were glowing red by the time he go the battery disconnected. Like was said I think a main battery disconnect would be a good idea.
might want to use a disconnect when using one of those "wireless" winch controllers. i watched a video of a guy loose fingers when some radio interference cause the winch to spool in at the wrong time pulling his fingers into the drum.
Glad he got it stopped in time. I had a buddy have the "IN" solinoid stick while winding in the line. It bent the frame and broke the steel cable before we could get it stopped. We simply beat the controller box with a rock and it worked.
we run a master switch in the live line between the battery & the winch solenoid, i have one large isolater to kill all 3 winches fitted to the vehicle,
it hasnt happened to me personally but i have seen it happen on another vehicle during a very heavey winch pull, have the solenoid contacts weld together & keep winching in even with the winch control switch not being operated,
although we do use the winches slightly harder than most with them either being over volted 24/12 or 24v systems with multiple motors
dont use these
http://www.ebay.co.uk/itm/BATTERY-I...tEquipment_Accessories_SM&hash=item1e6ce177ba
as they melt
i personally use this one
http://www.ebay.co.uk/itm/12V-24V-H...arts_Vehicles_CarParts_SM&hash=item4cffdb2bd5
with 3 winches running through it
That's what we did also, beat on the box with a screwdriver, worked fine the rest of the day. He ordered a solid state contactor the next week
When I started reading this thread I thought why would you want to do this....after reading the replies it makes sense to me. I personally have never seen a winch get stuck in position where it would not shut off.
Yeah, there was a thread here recently about a runaway winch that ended up breaking since the solenoid stuck and it wouldn't shut off. I'd say a battery disconnect would just be cheap insurance and I plan on putting one on my winch.
Here is the thread: http://www.pirate4x4.com/forum/showthread.php?t=1080045&highlight=
Here's the video from that thread. It can happen to anyone. There are pics in the thread that show the carnage. I have a switch now!
winch break - YouTube
This has been in the back of my mind ever since I came around a corner to see a park service truck hit a deer, and shortly after catch fire, all because the winch shorted out from the impact.
The truck would have driven from the scene had it not caught fire.
I've always kept my winch power cable disconnected (terminal w/wingnut). A stuck solenoid had never crossed my mind though. I just may have to look into a kill switch (at least my M8000's solenoid box is pretty much right up front if I ever need to smack it lol).
Discussion Starter · #19 · (Edited)
Thanks all for the responses and help. Would it be the same if i was to get a terminal for the winch only that has a on-off or is a kill switch better?
1 - 20 of 51 Posts
