1 - 9 of 9 Posts
If the pump is working and all the hoses are properly connected you could have plugged nozzles.
If the nozzles are plugged you can clean them out with a pin or needle but if the nozzles are plastic don't enlarge the hole because you will decrease the pressure at the nozzle (bigger hole = more flow, less pressure) and they won't spray properly anymore.
Can you hear the pump run when you hit the switch.
If not check power.
Power ok, check pump (pull and hook to other power source)
If it working but not pumping.
clean your sprayers.
a needle works.
or pull the hose off and shoot WD40 into them.
or aircompressor shot should blow them out.
1 - 9 of 9 Posts
